Post Benchmark Screen Shots Here!!!!
Quadrant benchmarking scores...
I just wanna get a general idea of what people are scoring in this category for this phone. Im very Interested in what over/underclock settings people have their phones at.
I personally score around 1300. I have my cpu set to 480 low and 806 high. Im run.img thundeROM and xionia kernel.
There's a thread dedicated to this in the LG Optimus S section.
ThundeROM 1.5 and xionia kernel :) this phone my (second) baby
There must me something wrong with my phone... I'm running nRom with my CPU overclocked to 825, with JIT AND acceleration, and I can't break 600.
Enable stagefright (flash the Deluxe buildprop) - you'll break 1000.
I just did that, ran a 1100, but I didn't like the effect it had on Youtube and other "media" applications. I think I'm gonna stick with JIT and hardware acceleration.
Got this with LegoRom, Zefie's Kernel Overclocked at 864 and deluxe buildprop. Got this phone on Saturday and seem to be able to run 864 stable. I've only had one reboot and that was when I checked performance in SetCPU. Otherwise seem to be able to run 864 for hours even though I am not.
Maybe this is not the right post, but i saw that the majority use ThundeRom and Xionia Kernel, how do you combined them? Also how do you do the OC??
Thanks
Thanks
ThundeRom now comes with a custom kernel that can be overclocked. To overclock search the market/web for either setcpuor overclocking widget.These apps allow you to adjust the cpu levels.
TO combine ThundeRom with Xionia kernel if you have the rom running on your phone already then just boot into recovery and flash the kernel.
So basically, I already have ThundeRom 1.6 so i just download kernel and flash it?? It won't substitute thundeRom?
Kernels are different then the actual rom.All flashing that kernel will do is overwrite the kernel you are currently running. You will still have everything that you see on your phone now.
Ok so i flashed Builprop Deluxe, but when i ran my score it can't beat 1000. I saw people in 1300's and 1200's, how do you make it? i have OC at 806 max and 246min scaling interactive. kernel 005 and ThundeRom 1.6
beezy posted this little guide in a different thread
Okay Ill give away the big secert
You have to warm it up .lol Here' s how i do it.
- install setcpu
- run stock speeds 600 /245 , run qaudrant 3 -4
times .
- go back to setcpu go up to 729 /245 run qaud
3 -4 times again.
- go back to setcpu go up to 748 /245 run quad
3 -4 times again.
- go back to setcpu go up to 806 /320 run quad
3 -4 times again.
- go back to setcpu go up to 864 /480 run quad
3 -4 times.
I seem to never have problems if i warm up
to it. I run the ondemand governor . If 864 / 480
reboots on you try 864 / 320 . If you try just
jumping from 748 to 864 you ' ll probably get
reboots. Now my secerts out
thanks beezy
Reactions: joakyno
I did all that you said but when i try 864/480 it reboot, so i put 864/320 and it reboot too. Right now i have 844/320.
everyones phone is different I can't go higher than 824 on mine. if I do it reboots. nothing is wrong with your phone. just some can take the higher settings and others can't. I leave mine set at 806/320
Curt RFD
