Post homescreen screenshots taken on your Samsung S7 Edge!
The S8 weather widget is available through APKMirror, won't show up on Nova but if you want that look for TW it's there.
Still rocking that S8 look
Nova Prime
GS8 Icons
Weather Widget is XWidgets
S8 Wallpaper
Screen shot of animation gif like Note 7 had to make animation gif on my S7 Edge
Nova Prime
GS8 Icons
S8 Wallpaper
I cannot decide whether I like the Zooper or XWidget weather widget better.
Right now I am using both until I can decide.
Decisions, decisions...
Nova Prime
GS8 Icons
S8 Wallpaper
I have noticed that my XWidget weather is off about 8 degrees. Do you know if there is a way to change providers?
I like XWidgets more because it doesn't kill your battery as much as Zooper does. It uses about as much battery as the stock widgets. It's only ever off by a degree for me. It uses AccuWeather which is pretty close to accurate. I'm not really sure how to edit providers. I do know the auto location doesn't exactly work correctly and I just add my city and has no issues updating the weather.
Thank you, I appreciate all the info. I do have it on auto, so I will add my city and see if that helps.
It should. Also if you're interested in turning stock TouchWiz into the new S8 look let me know.
Does Rectangle and Oval work for you? Animated Gif works for me but freezes when I use the other two. What all did you install?
I just install that didn't try the other 2 maybe if you ask in XDA someone might know, also the AOD from S8 here's mines on S7 Edge
Do you have the S8 Launcher installed?
Yup have it no issues plus you can add the app draw icon on homescreen or hide it by pressing home screen and go to touchwiz settings! Plus weather and weather widget is S8 Plus as well!
I had it installed but reverted back to stock TouchWiz, I'm thinking I need the S8 Launcher for the Smart Select to work. Appreciate the help and loving the custom themes you make
Looks like your right just tested no freeze here at all, so it works with no issues!
jades
