Post Your HTC Incredible Screens
Thanks. =)
The first screen is my lockscreen. I modded Widgetlocker to get the pink slider. The widget there is dClock, just modded to make the background clear.
For the second one, I am using Launcherpro Plus with custom icons and dock. The clock widget is simi clock and the weather is Beautiful Widgets I think.
The font is Neutrafont. I also changed the status bar's battery and removed the clock.
How did you mod widget locker? I am trying to get the sense lock but remove the time on the slider.
What rom are you using to remove the clock from the notification bar?
IDK how to remove the time from the sense lock within WL. Thats most likely built into the code. This thread over at XDA will help change the images.
My ROM changes from day to day sometimes. Its either the Redemption Rom, MIUI, or Ultimate Droid 2.0.
In the Incredible section at XDA, there is a thread with a file you flash in recovery to remove certain parts of the notification bar, but only if your on a Sense ROM. (I don't have the thread, but do a little but of searching, I know its there.) Certain ROMs like UD 2.0 or CyanogenMod have an option built into the settings to remove the time as well.
Reactions: TreyDaPrince
im wondering if someone can help me with a problem. i have my screen set up in 4 accross 5 up and down.
i made a 4x1 widget and placed it in the left bottom corner. there is a gap as you can see. is there anything i can do to get rid of it or at least make it as small as possible?
ok i figured out the problem. so im wondering does anyone know what the sizes are for the different widgets in photoshop. I would like to know what the size is to fill the whole widget area.
I like this setup! Just a suggestion, but probably my personal preference, it would look cleaner if it didn't have the labels underneath the word icons.
ps: Don't take it the wrong way, just saying my opinion. =)
Don't know how without switching Launchers. I like the HTC launcher. Coming from a OG Droid I'm tired of stock Android. I have file organizer and I know you can do it through there but I can't resize the icons. The original icons were way too small and I had to use desktop visualizer to make them bigger. Open to suggestions though.
If you are using Desktop Visualizer, just hit clear next to the label text box, and leave that box empty. It should remove the label, at least with mine it does. =)
*Photobucket is down, so I attached a screenshot of DV.
None too fancy, does what I need it to :) I'd hide the icon labels to make it a bit cleaner, but then I'd forget which folder is which.
-SkyRaider Vanilla 3.0.1 RC3
-Launcher Pro
-Beautiful Widgets
-Wallpaper found on Tumblr (fanart of Genesis Rhapsodos of FF7: Crisis Core)
Now why didn't I think of that...lol
Thanks.
Argent, your setup is insane !!! Just awesome !
Thanks! been playing around some more too :)
Desktop Visualizer
Beautiful Widgets
Launcher Pro Plus
Analog Clock Collection
[ROM] Skyraider Sense 3.3.4
and custom background/icons by me
Main Screen
Touching the word Social on the left side (or just swiping to the left)
Touching the word Games or swiping to the left from the Social screen
Touching the word Settings or swiping to the left from the Games screen
in any of the screens touching the icon in the lower left corner will always send you back to the main homepage (swiping that button activates the flashlight) and next to that is the App Drawer and then my web browser
Desktop Visualizer Help
I was wondering if anyone could give me a quick hand, or point me in the right direction.
When using DV, I set up my screen perfectly. All the images line up perfectly, and they look great. FYI, using the Picnik web app to modify pics and convert them to PNG's is great. Everything works smooth and I have no issues... Right up until I turn the phone on it's side and it goes into landscape mode. Then all the widgets spread apart and look like crap. I am using DV over LPP, and I don't know if there is a setting I need to enable in order for the widgets to look just as good as they do in portrait mode. Any help would be greatly appreciated. BTW, I am not on a Dinc (sad face) but on a Moto Droid. But you guys seemed to be the only ones actively using DV. Thanks again.
I would suggest to either disable Auto-rotation under the Behavior Settings, or if you want the landscape option then maybe change the settings in Advanced settings>drawer columns landscape from 6 to 5 or 4. Hope this helps.
Beautiful Widgets (for clock/weather and temp in notification bar)
Desktop Visualizer (for the people shortcut w/ custom icon)
The Droid Collection icon pack (for the People shortcut icon)
LauncherPro
I like to keep it clean and be able to see the wallpaper. I keep messing with it but I think I'm finally satisfied! :p
pratikkumarBB
