Post Your Screenshots!
What's that bar code on your home screen?
Hello. The barcode is actually my battery status. I use an app called minimalistic text and downloaded a barcode font. With that app you can customize tons. If you want to try and get this setup i will help you out. It's confusing at first using the app. :-)
Could you post instructions on how you made it? Thanks.
Sent from my MoPho
Sure, no problem
Make sure you have minimalistic text. Then download barcode font. Just Google barcode font and select first result(dafont.com) on your file manager make a folder called "fonts" in minimalistic app or if you have font changer place it there. Move the font to that folder.
Next open minimalistic text app and select layout then custom. There hold down the three selections in there and drag down to trash. Press the green plus symbol and select battery. Scroll till you see battery level bar and choose from zero to 100 and drag and drop each one to top box.
Once done go back and go to text style for normal, accentented and non accented select font and then barcode.ttf. change color to accented to see battery status. Just adjust size and color to your liking.
Its alot i know but if you get stuck let me know.
Reactions: donut
Here's my current main home screen. Nothing special. Deciding whether to convert my background to 8bit or just go solid black.
Here is my current:
Click to view quoted image
CM6.1 RC1 with Impaled Blue theme
SiMi clock widget
1x1 Beautiful Widgets weather widget
Sent from my CDMA Hero. I got some hot Froyo-on-Hero action here!
SiMI just replaced Go Weather as my clock and weather widget. THANKS!
For everyone else...I just put one on, but what is the point of having a battery icon in the status bar? Other then a percentage/ number it's still a graphic.
My Orange ICS Halloween theme on my HTC Sensation hope you guys like it :D
The wallpaper I got it from Cyber Warrior collection and the lockscreen as you can tell its CM7.1
I decided to go the full (mostly) 8-bit route for my home screen. So here's my latest update. The four well known characters along the bottom are shortcuts.
Do you need the icons or wallpapers?
Nope. Just did some searching and found them. Also I found a go launcher theme that has everything included. So its all good. :) ill prob upload some new screenshots soon.
Sent from my Nexus S 4G using Tapatalk
I like that a lot actually. Nice work!
Ishimwe
