Post Your Screenshots!
Hey. I actually got the icons on a thread over on XDA. They are called cold fusion HD. Here is link
http://forum.xda-developers.com/showthread.php?t=1430033
Clock widget is from uccw app. Theme is called circles.
Here is link
http://forum.xda-developers.com/showthread.php?t=1387518
Don't know if you have used uccw before. It takes a bit of time to learn.
Thanks!
Update: I'm getting a parse error while trying to install. Any help?
____________________________
NoobTech: Www.kkapoorr.WordPress.com
[ICONS] Cold Fusion HD - (708 icons) Updated 15MAY2012 - xda-developers
Here is link
[WIDGET] UCCW - Ultimate custom clock - skins - xda-developers
I cannot for the life of me figure out how to use UCCW. How do I get the themes to show up?
Simple for me.
Sent from my Gnex Golem.
Yeah it took me a bit of messing with it to figure it put. When you download the app it creates two folders on you SD card. One is ultimateclockwidget and the other is uccw output.
Once you download the themes zip, extract it. If its a .uccw then you move that and the .PNG files to ultimateclockwidget folder. If you have weather also move that into the folder but in the weather sub folder.
Now if you extract and it shows a uzip then you just move that uzip into uccw output instead of the ultimateclockwidget.
Open uccw widget from your app drawer and select menu. Then select open/manage skin. From there it will pop up a list.(this is where the .uccw are stored) it will load.
Now if it's a uzip then open app. Select menu and then select import skin. The theme will load and then your set. Its easier if its a uzip.
Now just select widget on your home screen and adjust to size you want.
Sorry for taking up a thread that's meant for screenshots but I just wanted to try and help for those trying uccw. If you have questions feel free to pm me and I will fry to help out.
Sent from my HTC One X
Been using this launcher theme for a few days now. I like the lock screen as well but will probably swap out the background for something lighter.
Edit: I suppose I should've waited until the screen cap notification went away. :P ah well, I'll probably change it up in a day or two anyway.
I'm getting a parse error when I'm trying to install the Cold Fusion HD icon pack apk.
Really liking these icons. Help me!
NoobTech: http://wp.me/2uu9r
What launcher are you using? After I downloaded the zip I went into my filemanager and extracted the contents.
Make a folder on the root of SD card for icons. Move them into that folder. You can also just leave them where they were extracted to. I just like keeping it organized. Pm me and I will help you further.
Not as fancy or technical as others but its me. Still learning. Droid Razr. Beautiful widgets.Simple calendar. Color notes.
Marg
