Power Control Android Widget
rinnr1
Press ALT-F4 to see nudes
May 12, 2010
176
So I'm using the Android Power Control widget and I don't know what this one icon does.. I'm at work so I can't check the manual :(
Anyone know?
Thanks
I believe it's whether your data refreshes... not SMS or MMS, but things like facebook, Google talk, etc.
I could be wrong, so take that for what it's worth...
i believe it stops your email as well... basically stops the phone from pulling data (aside from calls/texts as cae2685 mentioned)
Exactly. Turn that off and you turn off auto sync so you'll have to manually hit refresh on your email.
KidColoringPage
