Power saver question
Blaalad12
304
Hey guys, I often force close power saver just to remove it from the notification bar so i dont have to see it, But today i did so whilst power saver was actually running and when i viewed "power' in settings it still said power saver was on? So iam wondering is it possible to have power saver on whilst removing it from the notification bar? Naturally iam assuming force closing it turns it off but wasnt sure after today
Yes, closing the app behind the notification does not affect the power saver options that are on or off at the time. You can test by turning power saver on and disabling vibration.
After you force close vibration is still disabled.
Now go back and enable vibration with power saver on. It will still be enabled, etc.
Awesome so i can have power saver on the whole time without having to see it in the notification bar :)
Yes, it appears that way to me. Although, I can't speak for if it is doing something behind the scenes differently, but the listed functions appear to work as set whether the notification is there or not.
They should have just allowed you to toggle the notification imo.
Quiant
