Power Saving Mode
Rei604
has anyone been able to figure out how to get rid of the completely useless Power Saving Mode notification from the Notification Pull-down Window and the Lock Screen?
I know I have that damned thing on I don't need the reminder.
I can't exactly remember where i went to, but in my attempt to fix it I ended up holding down on the notification to get the name of the app and then went and blocked it from pushing notifications onto the lock screen (as it solved one of my problems) but now every once and while something will push itself onto the lock screen and since iv blocked that one app, it still shows up on the lock screen with a black notification box that says "content blocked". As this clearly didn't work (and only solves the lock screen issue) i was hoping someone else managed to have better luck.
My phone is not rooted.
P.S is there a way to manually set up my settings so that it is essentially ON power saving mode without the bloody thing turned on? because ill take that as well.
Greetings!
Have you tried going into Settings > Notification panel, and then "customizing" it from there? Hope you get what you intend resolved. :cool:
witnessloc03
