Phone: HTC One m7
Carrier: T-Mobile
Rooted
So I customized my power toggle & on it I added the shutdown & restart switch. Whenever I try to use those options I get an error saying "The command failed. This can be either because your device is not rooted or you did not grant the root access to the app."
As mentioned before I am rooted & I did make sure I granted permission.
I even went into supersu settings, scrolled down to "enable pro" (just to see if that made a difference) & checked it off which actually enabled the features.
Has any had this issue? I would appreciate anyones help on fixing this issue.
Thanks in advance!
Carrier: T-Mobile
Rooted
Thanks in advance!
