Question Pre recorded message
GIRW
10
8
3
I would like to tell people that I contact by phone that I have a stutter and that I probably will not start talking immediately.
Is there an APP that will allow me to pre-record a message like this
"I have a stutter. My name is Graham Williams. Please would you mind waiting while I get my first words out. I do improve after the first few seconds.”
This would save so much time and less frustration for anyone receiving a call from me.
If nothing available would a developer possibly think about doing this.
Thank you
Graham
Solution
Tap the Settings option (gear icon) in the lower-right corner of the app. Scroll down to "Play Sound Audio Stream" and you'll see it.
Finally got it working. The TTS message can now be played at will. I have noticed that I need the volume turned up high for this message to be heard on the receiving phone, so perhaps this works by audio coupling between the speaker and the microphone.
Another advantage of this floating button is that I can play it when using my landline.
I shall carry on tinkering with it, thank you for your help.
Maybe consider a pre recorded message on a digital recorder (or anything that will record ie old phone), that you press play and put next to your phones mic when making /receiving calls.
You could have multiple greetings Pre-made to select from as well.
Good luck
Thank you for this. I now have a pre-recorded message on my Android phone that I can play at any time. Can also play this message over a landline speaker.
With reference to previous answers it makes use of a macro app that displays the "Play" button permanently on top of the screen..
Reactions: methodman89
LilPandaBear1105
