Preorder updates..
If you download from plays tore, the ones on the phone are not, you can change there order only
Sent from my SGH-M919 using Tapatalk 2
+1 what is blocking mode
its like do not disturb on the iphone. it blocks all incoming messages, alerts and phone calls if you want it to. it can either be turned on, or turn on by itself at a specific time. and verizon deems it not useful or something apparently because they keep removing it
I think Verizon has a premium device to block specific numbers. Idk, throwing ideas at the wall.
Sent from my shattered, re-stocked, Airplane Moded VZW Galaxy Nexus using Android Central Forums
its not for blocking numbers specifically. its so that when youre sleeping, you dont get disturbed. your phone wont go off, the screen wont light up, etc
So Does it have Blocking Mode or Not? I know the S3 didnt, but hoping for a change with the S4......
- - - Updated - - -
Mine FINALLY left Tennessee POR FIN! :thumbup::thumbup::thumbup::thumbup::thumbup::D:D:D:D:D:D:D
Sent from my GT-N8013 using Android Central Forums
Good for you.........pee-pee dance coming up.........mine is still just sitting there pickin b u t t :D
What's wrong with using Airplane mode? Sounds functionally similar when you describe it like that.
package not due for delivery until tomorrow
that feel when you know its less than a 10 minute drive from you and it will stay there for at least 24 hours
that turns everything off, when you put blocking mode or do not disturb, all the alerts still come through to the phone, you just dont see them until you unlock the phone
You can still have unimportant reminders and the like making sounds and lighting up the screen. There's plenty of stuff which light the phone up and make noises that don't require Connectivity. Hence the do not disturb mode which will only leave alarms.
- - - Updated - - -
pick it up from the facility bro!
i was told you cannot do that. the only time you can do that is if they attempt to deliver to your house but you're not home or something so they save it for the next day.
can't imagine how excited everyone must be :D
Ah I see. OK, that makes sense.
On the site you can request them to hold it at the facility. I never bothered with that though. I always just go there and pick it up. They really don't care
vdacau
