problem building a toolchain with buildroot
brokdikdog
Active member
Feb 4, 2011
27
I've been trying for two days to build a toolchain so I can compile an LG Optimus V kernel but I keep running into this problem. After I run make it runs for a bit and says
[INFO ] Performing some trivial sanity checks
[INFO ] Build started 20110401.211725
[INFO ] Building environment variables
[EXTRA] Preparing working directories
[EXTRA] Installing user-supplied crosstool-NG configuration
[EXTRA] =================================================================
[EXTRA] Dumping internal crosstool-NG configuration
[EXTRA] Building a toolchain for:
[EXTRA] build = x86_64-unknown-linux-gnu
[EXTRA] host = x86_64-unknown-linux-gnu
[EXTRA] target = arm-unknown-linux-uclibcgnueabi
[EXTRA] Dumping internal crosstool-NG configuration: done in 0.07s (at 00:01)
[INFO ] =================================================================
[INFO ] Retrieving needed toolchain components' tarballs
[EXTRA] Retrieving 'mpfr-2.4.2'
[ALL ] --2011-04-01 21:19:00-- http://www.mpfr.org/mpfr-current//mpfr-2.4.2.tar.bz2
[ALL ] Resolving www.mpfr.org... 152.81.144.6
[ALL ] Connecting to www.mpfr.org|152.81.144.6|:80... failed: Connection timed out.
[ALL ] Retrying.
[ALL ]
[ALL ] --2011-04-01 21:19:12-- (try: 2) http://www.mpfr.org/mpfr-current//mpfr-2.4.2.tar.bz2
[ALL ] Retrying.
[ALL ]
[ALL ] --2011-04-01 21:19:24-- (try: 3) http://www.mpfr.org/mpfr-current//mpfr-2.4.2.tar.bz2
[ALL ] Giving up.
[ALL ]
[ALL ] File `mpfr-2.4.2.tar.bz2.tmp-dl' already there; not retrieving.
[ALL ] --2011-04-01 21:21:08-- http://www.mpfr.org/mpfr-2.4.2//mpfr-2.4.2.tar.bz2
[ALL ] Retrying.
[ALL ]
[ALL ] --2011-04-01 21:21:27-- (try: 2) http://www.mpfr.org/mpfr-2.4.2//mpfr-2.4.2.tar.bz2
[ALL ] Retrying.
[ALL ]
[ALL ] --2011-04-01 21:21:39-- (try: 3) http://www.mpfr.org/mpfr-2.4.2//mpfr-2.4.2.tar.bz2
[ALL ] Giving up.
[ALL ]
[ALL ] --2011-04-01 21:22:46-- http://www.mpfr.org/mpfr-current//mpfr-2.4.2.tar.gz
[ALL ] Retrying.
It does this over and over until it just gives up. Does anyone know what I am doing wrong?
Nevermind, I just downloaded this package from google code site and placed it in the proper folder under packages and restarted make and it worked.
Sent from my Optimus Stalker
zolepso1
