Problem Identified for Gallery Force Close Issues
force close for whatsapp not working on my note 5
before getting my note 5, i use always force close whatsapp. since im using my note 5 its not working.
the idea when someone send me a whatsapp and i dont want them see double line, i force close whatsapp so it gives as if my net closed. hope can understand why not working. thank u
melanie
UtahConcealer - In addition to the above procedures, you ALSO need to clear the DATA (if you clear just Cache, it may not work).
THEN you must also clear both Data & Cache of the Media Container Service.
So you need to clear Data AND Cache for:
1. Gallery
2. Media Storage
3. Media Container Service
Reboot after that and you should be good to go.
Note that you will also lose any playlists (so make sure they are backed up if you want to keep them, and then you can later restore them). Plus you will have to re-setup any ringtones you had.
I can't find Media Container Service anywhere on my phone. Please help!
I noticed that a number of users have reported that they usually have gallery force close issues after some apps updates from time to time so I attempted to duplicate and identify the issue for sure and was able to finally trace the problem down to a small .nomedia file that apps place into there program folders to stop the image files from the apps to show into the media gallery to avoid the images or audio files from being accidently deleted. Others thought that the nature of the problem has been because of a corrupt file but in the end it was the .nomedia files. Apparently this confuses the Gallery app because a number of files will be present in cache that this file hides from the system and this seems to cause the Gallery to act as if a corrupt file is present, this also seems to effect the camera app from time to time.
Also remember that the solution will clear the personal settings data from Swipe and sometimes clears alerts settings that can be restored from Titianium Backup easily.. So backup before doing solution to avoid headaches..
The fix this issue is to goto Settings/Applications/Manage Applications/All Tab/ Media Storage and then clear the Cache, then reboot and then open gallery and allow images to be scanned and added back to te gallery (This may take a little time depending on the number of files)
http://forum.androidcentral.com/attachment.php?attachmentid=7881&stc=1&d=1301242634 http://forum.androidcentral.com/attachment.php?attachmentid=7882&stc=1&d=1301242634
http://forum.androidcentral.com/attachment.php?attachmentid=7883&stc=1&d=1301242634 http://forum.androidcentral.com/attachment.php?attachmentid=7884&stc=1&d=1301242634
i tried all of these suggestions,I'm still having this problem. is it probably a virus? (I'm very new in this stuff )
tahirmehmoodkhokhar786
