Question Problem in developer options in display cutout
wp patrick
58
4
8
Hello everyone my name is Patrick and my problem now are developer options failure in setting my story i did change for try in display cutout but i can not go back to normal one because it stuck in last one what i did change so help please can some one tell me how i can quick fix it. Thanks.
To be clear -- are you saying that you modified the display cutout appearance in Developer Options, and now want to change it back?
I want change back when is possible in camera hole cutout what it was before or in device standard but it does not work anymore others work perfect but problem i want set it back in camera hole cutout what not happen because it stay in the one what work and not in what i want and that is in device standard or camera hole cutout so help please and thanks again.
Go back in developer settings and change back what you changed
Hello thanks for help i did go back but what i want what was before does not work others works perfect but i do not like so i want set it back in camera hole cut out but problem it stay in last one what work like corner cutout what i dont like so help please
So when u choose which u wanted it doesn't revert back? You tried rebooting the phone afterwards?
I reboot my phone and still the problem after that i did turn off developer options for a while now i did turn on the developer options with still the problem only first two set choice in display cut out does not work for set it last four choice does work completely but i need the first two options so help please and thanks again.
Ok so to understand you correctly u can't get back the default screen? If this is the issue then try safe mode then exit out see if it gets corrected otherwise u will need factory reset
Hello again i wait with reset factory because it come back when need like do that in phone so i wait and last question i still shall receive update Android 15 for phone maybe that will help or must i wait with update when problem still in developer options for display cutout many thanks again.
timdavid33
