Problem Installing ROMs
DeCourseyyy
169
9
This happens with most ROMs I attempt to install. Here is an example with koush's ICS ROM.
Installing update...
assert failed: getprop("ro.product.device") == "
crespo4g || getprop("ro.build.product") =
= "crespo4g"
E:Error in /sdcard/Root/cm_crespo-ota-eng.koush1
0.zip
(Status 7)
Installation aborted.
Suggestions?
could be a bad zip, i'm running that and i know it works great.
i'd go grab the latest version, alpha 10 as of writing this, and then make sure you do a full data/wipe and wipe Dalvik.
For these early builds where a bunch changes between builds it's very important to make sure you wipe everything.
grab the new Matrix 11 kernel for ICS (make sure it's the ICS one and not the GB one) it's awesome.
hope that helps!
958ryan
