Problem of the Nexus 5
Nicat Kerimov
4
My device Nexus 5 16 gb with android 4.4.2kitkat all stock.The problem is that the phone itself is locked in any application such as now when I write a message has to press several times to unlock. Please do a full reset. And it worked fine but when put a couple of programs namely program premium widgets then the phone started again blocked.Than you in advance!
Welcome to the forums.
Does the problem seem connected with Premium Widgets?
There must be something up with your apps. I would do another reset and slowly add your apps back. 2 or 3 at a time for a day or two, to narrow down which ones are causing problems.
I'm having 32gb Nexus 5. Day dream option is not working for some reason. Can somebody help me out?
"Settings"
Sleep: after 30 secs of inactivity
Automatically lock after 2 mins
Daydream: On
In case: enabled widgets
Daydream: charging, docked, either. Tried all three options. It's working while charging but not while docked.
Used Dashclock and normal clock as well. It works while charging but not normally. (It's not working on daydream when docked.)
Ashok Dharshan
