problem uploading screenshots?
funkylogik
9,631
111
is anyone else having problems uploading screenshots via the AC app? it either tells me its wrong dimensions or if i try "small" it just says upload failed :(
used to work fine but now it fails more often than not. surely all screenshots are the same dimension?
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or crazy) guess ;)
34 views and noone even replied to say they havent had the problem :( poop :p
guessing its only my problem. wonder if reinstalling the app would work?
dont wana go back to using dropbox links.
p.s.. just noticed its not only screenshots, its any pic.
was playing around with cam settings the other day, would changing anythin in cam settings affect the screenshots in any way?
Yea man,i am too. It wouldnt let me,it also said dimensions where wrong.
Sent from my S3(:
I as well have issues but only with certain screen shots
On my Samsung galaxy s3 running android 4.0
Because unlike ios, i keep my apps in app drawers, and not in infinite cluttered homescreens
so do u think its a problem with latest app update mate?
and are you in a position to report it and be taken more seriously than the rest of us?
I will notify Administration of this problem. FWIW, I had it happen to me earlier too...
cheers paul mate ;)
take it its a Tapatalk fault?
does the problem still happen usin the full tapatalk app anyone?
Nope, nothing gets done on this forum anyway
ill bump this anyway coz ive noticed a lot of people with same issue... makes the homescreen stickie pure annoying to use lol
any updates on this issue.
it seems like sometimes when you select the pic, you get the "hosted by tapatalk" option but not "this forum" and appears to be completely random :confused:
p.s, how do i edit the title since its not only screenshots affected (could a mod edit it if possible?)
cheerz :cool:
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess ;)
Mine worked. I always use "this forum" to upload screen shots
I have problems uploading screenshots sometimes, maybe it has something to do with my file being saved in a .png format? Ive noticed several pictures being saved in this format instead of .jpg depending on the program I'm using. what gives..
yeah but surely all screenshots are saved in same format and dimensions so why do some upload and some dont? :confused:
cheerz :cool:
Go to edit > advanced > you should see and be able to edit the title above the message editor box.
FYI.. It's a known problem and is being worked on.
Yashnareddy
