Problem with camera flash
hydrolynx
6
I have a problem with my galaxy tab 7 plus that the flash light seems can't be adjust (colored grey) at camera mode and after taking a pictures from the camera, the flash will automatically be activated and cannot be turned off until I reboot my tab.. Its very weird, now every time I take picture, I need to reboot the tab and it is extremely irritating.. Anybody encountered the same issue here?
I will see if I can replicate this problem. I hardly ever use the Tab camera. I will get back to you tomorrow.
I will need to look at this tonight since I forgot to bring the Tab with me to work. :( My apologies.
I still cannot manage to fix it, after few applications remove, thought it was caused by camscanner.. After i uninstall camscanner, the issue still there..
Sent from my GT-P6200 using Tapatalk 2
I had a similar problem on a brand new SGT7+. When I opened a photo I had just taken in the camera app flash would stay on and only way to turn it off was to power cycle it. Exchanged the tablet and now no problems.
Hi all;
I have had the same problem a while a go and it can be cured by doing the following steps: (www.kaskus.co.id):
- tap setting
- tap accesability
- undervision, you see: "Torch light". The box next to this tittle should be un-clicked.
Let me know whether you are success or not.
Regards, Viator
Yashnareddy
