Problem with earphone connection
also have a grand prime.tried the "soundabout" and it dont work;which is funny.it worx on my old phone and laptop.idk what u did,but my headphones are made 4 androids,they r sonys,and I am really angry
hi
I have a problem in my galaxy grand 9082 ( 1st grand ) model phone working in normal way but when i want to listen or watch something into the earphone the sound is not coming without earphone its run in good what should i do to connect it i was checked 2 different earphone but no working may in phone problem so kindly give the solution
pockoc
I had the same problem with my S4 mini on a rainy day while I was waiting the bus. While I was browsing suddenly the icon and the sign for headphones connected showed up without any headphones being connected.
What I did is to put the headphones jack and twist it a couple of times. It worked
Fri Jan 23, 2015 3:54pm.
Hi,
this was the easiest way for the problem of having the headphone icon when it is not plugged in also. I just took my earphone and tightly plugged that in and I pressed it and twisted it . And when I saw my display , that icon was vanished . I think it was some air lock.
BUT IT REALLY WORKED .
THANKS A LOT ,
POCKOK
What I did is to put the headphones jack and twist it a couple of times. It worked :)
This worked for me. Thanx for the solution.
my problem in my samsung galaxy j1 on earphone is when i insert it it have no sounds or music it just have sound like like that
and no music if i insert the earphone on my phone but when it is in speaker mode it have sounds but in earphone sounds
WHY is like that and plss help me
I had to same issue my j2 too showing same thing
After I read this website is install soundabout app
And magically my device speaker and sound working within 5 min also now I am able to listen sound during call without speaker
Thank you very so much
Thanks BRIJ PATEL! Your solution worked just fine for me! (Y)
This is not a settings issue. The contacts inside the headphone jack are shorted out, which tells the phones a set of headphones is connected.
This can happen due to a tiny drop of water, humitity, a sliver of aluminum foil, etc.
The easiest way to clear and fix this issue is to blast a bit of air from a compressed air can into the headphone jack. You can get compressed air cans for a few bucks at any local office supplies store, Fry's, Office Depot, etc.
Just a short blast or two will clear the problem.
Or Blow air with your mouth for few times!!
Although I do not have any earphones connected to my Samsung Galaxy S3, the phone thinks I do and has no sounds audible. If I do plug in earphones, they work fine. But, unplugging them does not remove the earphones connected icon, nor does normal sound return. Is there a setting that will correct this problem, or should I seek repair? I have tried powering down and re-booting, with no success. Any suggestions?
Dial any number and turn speaker ON , then turn it Off. problem resolved :)
ZackS
