Problem With Galaxy Mini and memory card 8gb
Mar 14, 2014
7
H?llo
I Have Adata Memory Card with 8gb . iT worKS NormALY In My Phone Samsung Galaxy Mini 5570 But it works Only with 4gb because of file sysyem wich Is Fat32
I Tried To Format It with NTFS Or Exfat SYStem it can Work with more than 4gb but when i place it in my phone he told me that he can not work with it so he re format it with fat 32 system and we back to the 1st Probl?m :mad:
H?llo
You could have a problem with the sdcard. Have you tried getting a replacement or inserting another brand sd card to see if that allows you to use the full storage capacity in Fat32?
Just another note, make sure you are formating the entire card to Fat32 and not creating a 4GB partition that is Fat32.
But Like we Know The disk that is In Fat32 can have only 4gb even he is 8gb full
when i format this card with NTFS it work normaly in the computer i can transfer with it 7.5 gb normaly but my phone can not identify it he say that i must format it with Fat 32
Have you tried to format it from the phone itself?
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
Yes when i Format it with the phone himself ... he format it with SYstem Fat.32 .. So I CAnt work with the full capacity 8gb this us the probl?m
I'm thinking that the device is creating a partition with 4GB of Fat32 storage. You might want to format from a computer and make sure the card is being formatted entirely and not being partitioned with 4GB of memory.
I was able to format a 64 GB microSD card in FAT32 to use all 64 GB of space. So just because it's FAT32 doesn't mean it should reduce the usable space of the card.
But we All Know The System Fat32 Can Not work with more Than 4gb .. I know you can format with huge capacity but you can work with small capacity -4gb
This IS Global Fact . Google It
4 GB is the file size limit for FAT32, not the total card capacity limit--I was referring to the total card capacity in my previous post.
oh Sorry I was wrong .. The fat32system can have more than 4gb file .. but he can not have one file with more than 4gb file .. he can have files 2gb and another 3gb so he is 5gb but he can not have one file 5gb impossible and this is my probl?m
If your phone can only use FAT32 on its SD cards, then you'll probably have to live with the 4 GB file size limitation.
Humanlymortal
