I have the Motorola micro-HDMI to HDMI cable. I'm connected to a Vizio TV with HDMI input and other devices connect just fine through both HDMI ports. I have tried every possible sequence of connections and the Vizio consistently shows "no connection" status. Most recently I have been powering off both Razr and TV, then first booting the Razr, then starting the TV.
When the phone boots, it displays an "HDMI cable connected" message and the display flips 90 degrees as expected. I have checked the HDMI settings (accessed from the home screen menu) and all seem OK.
When I was running GB, and possibly the earlier ICS version, I seem to remember a menu popping up when the HDMI was properly connecting. I don't see that now. I do know that earlier at some point I had no problem connecting.
I doubt it's the cable or the TV. Could someone please venture a guess as to what is wrong?
Thank you.
Frank
Thank you.
Frank
