Problem with my Xbox One controller for my OnePlus 6
  • Start date Start date
A
Android Central Question
I feel as the triggers and the right analog stick doesn't work, I'm using an OTG connection so it's all wired not bluetooth, does that matter? Anyway, the right analog stick seems to drift endlessly if I move it once in any game, it drifts in on direction only... And as for the triggers, well I tried the Modern Combat 5 esports game and the triggers did not shoot or aim so clearly they didn't work as normal either. Anybody knows whats up? Every other keys and analog stick works though.
Thanks
It does if the controller requires a driver - which you won't find for Android. Some controls will work because they look like normal electrical switch closures, but some won't because it's the driver that interprets them.
So what can I do...? So then wired is somehow worse than say bluetooth or what? I didn't quiet understand what you meant
Thanks
kiki2025
