Problem with sounds
matt530
6
Recently the sound on my Optimus S has started acting up. Calls, e-mails, and text messages still make sound,. But media and screen selections make no sound. Also, if I'm making a phone call, I cannot hear the other person, unless I turn the speakerphone on. I've tried turning the phone on & off, doing a factory reset, and I checked to make sure that the media volume is up and that the phone is set to play a sound when screen selections are made, but nothing has worked. Anyone have any suggestions before I take my phone in to be serviced? I've only had this phone a little over a month
Try installing Volume Control from the market and see if the volumes are all where they should be.
Sound's like the headset jack is stuck. My son's optimus had the same problem. He was using headphones for his music and one day he remove the headphone jack and that started the no sound. He could only make and receive call with the speakerphone option. Sprint did replace it for free. My palm treo's were bad for this. I have 4 of these LG's on my account, so I hope this won?t be a common issue.
Didn't have a headset plugged in, but I guess anything is possible. phone has been great so far otherwise
Louddawg, you might just be a lucky charm. right after I replied to what you suggested, it suddenly started working again
Hrm, the kind of flakiness you describe there sounds hardware related to me. I would suggest bringing it back for a warranty replacement.
seems to be working pretty consistently now, I think there might have just been dust & metal shavings in it (I'm a metal fabricator). I blew it out with some compressed air, seems to be working fine now
sokatvo2
