Hi. I have a problem.
I'm using a Sony Ericsson Xperia X10 White (running on 1.6) from AT&T, I'm trying to get the Sideload Wonder Machine to work, but it keeps encountering an error saying "Device Not Found". I tried the Troubleshoot option, and I do not see the serial code, which means that probably my USB Driver has problems. However, using Sony Ericsson PC Companion, I can load music, photos, etc. to or from my phone, which should indicate that the USB connection is connected correctly to my PC. Within "Development", USB debugging is also enabled. I am using Windows 7 with Microsoft .NET Framework 4.
What could be the problem that is causing SWM to unable to locate my device?
