Problems Factory Resetting (Or Resetting in general)
msng110
5
So I've got a Samsung Galaxy S3 Mini. I downloaded the unofficial firmware (4.2.1 I believe) over the stock firmware (4.1.2) and I forgot to wipe Dalvik cache, Cache, and etc. Now I end up with a fuzzy bootscreen, which then leads to the normal Samsung animation. I am unable to access recovery, therefore, I am unable to factory reset or wipe cache. I want to install Cyanogenmod 11.
Is there any alternate method where I can factory reset, or the same method with a fix on my current problem?
When you installed the unofficial firmware over the stock, was it with Odin or did you flash with a custom recovery (rooted)? You should be able to re-flash a stock ROM and flash with Odin. You'll then need to root, at which point you can install CM11.
