problems syncing with my pc
goater1220
60
4
So I tried hooking up my tab to my laptop and it said no drivers found for device, can someone please help with this issue.
If all you want is to access to the SD card then you don't need a special driver. Just hook it up to the computer, pull down the notification bar, choose the USB connection, and change it to USB Mass storage. Also turn off USB Debugging.
EDIT: Nevermind...I see you got it.
Lol thanks for the response. I do want to root it and overclock it do they make different roms and kernels for a verizon tab?
kankuraon
