Problems Unrooting DINC2
GreenAcid82
I Rooted my Incredible 2, via Revolutionary. about 4 months ago. and I was running CM7...I got offered to upgrade my phone from Verizon, so I decided to Unroot my DINC2, and get it back to stock, to put on EBay or what have you...Anyway
I STUPIDLY used something called "Gingerunroot" from the marketplace...Figured that didn't do the trick, and Googled how to unroot it normally. I Flashed to 2.2.1 sucessfully, and I have S-ON, when I boot doing vol down and power.
My problem is, I CANNOT update to 2.3.4...When I Try to go to Software Update, it says "SERVICE UNAVAILABLE PLEASE TRY AGAIN UNDER SETTINGS SOFTWARE UPDATE"...Over and over..At first I figured it was because I was in a bad signal spot, but then I was in a 3G area with Really great signal (Almost full bars) and it still said it.
The other problem I'm having is, If I remove my SD card, I Lose signal. like, it goes to xIIII <--bars...and i can't even dial.
I'm guessing I'm gonna have to Re-root and unroot it with the steps I did before, Minus the Application...or is there another way around this? I was pretty sure 2.3.4 Came with my DINC2, so It's really weird that the stock flash I found was 2.2.1...
Anyways. Please help. if I didn't post this in the right area, Please move it. but keep in mind my phone is "Old news" and not too many people will likely read it if moved to the DINC2 section.
