Problems with 3rd Party Messaging Apps
Nekoxii
7
I have an HTC one M8 with T-mobile and I've tried different messaging apps like Go Sms, Evolve Sms, Textra, and many others but no matter what I can never send MMS on any unless it's on the stock messaging app or Hangouts app. I even configure the APN settings on the apps and it still doesn't work. Can anybody help?
Sent from my HTC One_M8 using AC Forums mobile app
Hello.
Make sure you have data enabled. Try seeing if turning off WiFi while sending it will fix it.
Sent from my One Xl using AC Forums mobile app
Hello.
Thank you I do have data enabled and I turned off my wifi and sent an MMS and it worked! Thank you:) guess Ima have to turn off my wifi when I send an MMS from Now on.
No problem! Come back to Android Central if you have any more questions.
mostafamu
