problems with 5.1.1
Koko On
3
I just got the 5.1.1 update yesterday and is already driving me nuts, touchwize is lagging, the fingerprint scanner just stopped working, some notifications don't work the battery is holding up but the signal is failing a lot. Non of this was happening before!
Is there anything I can do about this?
What carrier are you on? And I'd try a cache wipe and see if that fixes anything
Still having the same issues on TMobile Unlocked on 5.1.1 I'm about to flash back to the previous version. N910T3TMB1DOFC. Depending on what carrier, you could perhaps do the same, not sure.
The new software version of 5.1.1 lollipop is useless, nothing is different. NO update camera and other apps are the same. Some people saying that this new version is faster, but I don't think any different. I suggest to Samsung that the camera should be updated as it's not good enough for Galaxy NOTE 4.
Fingerprint unlock seems to be the mayor cause of problems with 5.1.1 Change it to pattern, password or pin unlock and see if it solves the issues.
Beanz2003
