Problems with Accounts
russ8128
55
Hi...first time poster. I don't know if anyone else has had these problems but now that it has happened to me another time I figured I'd reach out. Two times I have had to reenter my account data. I go and check my emails and the emails are not there. The accounts show up at first then disappear. When i try to add the account back it says that I've already added this account - but its not there, just the add account list. I restart the phone to no avail, do a battery pull...same thing, nothing. The first time i had to do a factory reset - what a pain. This time I was able to add my exchange account and pop accounts back (no aol though). I should add that i've never lost my gmail, twitter or linkedin accounts.
Any thoughts?
Sounds like something with the phone...maybe a bad internal SD? At any rate, since you already did a factory reset. Return it and get a new one. There are far too many bad units floating around. Make sure that you check the phone before leaving the store.
njira
