Problems with booting to recovery
joewknap
3
i press vol down home and power like the instructions say and all i get is a black lit up screen. i tried using command prompt to boot to recovery and it stays stuck on the lg bootscreen as does ROMtools reboot into recovery. whats my problem? thanks in advance for any help
Are you plugged in when trying to goto recovery that usually is the problem. If not try pulling the battery pop it back and use the power down and home button. Last I would reflash the recovery.
thanks
Problem solved. Thank You!!! Now i just have to figure out how to get gingerbread on this thing. Again Thanks So Much!
Casperxx99
