Problems with Bugless Pete's kernel and BLN?
vertigosrs
108
3
So for some reason BLN randomly stopped working. I'm using pete's kernel and the latest version of miui and things have been fine until yesterday I noticed BLN wasn't working. I went into the BLN control and it says: The BLN mod is not installed. Do you like to open a website to get help? Anyone else experiencing problems or have any idea why this is happening?
His kernel support BLN
His ROM, GPA17, uses his kernel, which supports BLN
I'm running GPA17 and needed to install BLN Control from the market in order to get BLN working. Now that was 3 builds ago, so I'm not sure if anything has changed since then.
You said you are running MIUI so I'm not sure if that complicates things at all.
hope that helps!
bogorshop
