Problems with clipboard and pasting pictures and sceenshots
charlibob
202
3
When I place images in the clipboard it is usually not possible to paste them anywhere. Once in a while it works, but only rarely. The OTA upgrade hasn't helped. No problems copying and pasting text. Any solution?
Have you found that it works better in some apps than in others? What are the ones it works in when it does work?
Where are you copying images from? The browser, for instance? I tried a couple of things, and couldn't use Gallery to copy a picture to the clipboard at all, nor the Opera browser, only the stock browser. I was also able to get a screenshot onto the clipboard.
Once I had an image on the clipboard, though, I was able to paste it into an S Memo (and to see it in the clipboard list that's available in S Memo and a few other apps). Is S Memo one of the apps where this doesn't function for you?
slackingfred
