Problems with CM7
boyer61
156
5
Well i've had some odd issues with CM 7. And instead of me clogging up the thread about CM 7 i'll just make my own.
First one is, with Beautiful widgets. I like to use google weather and geolocation. When i enabled geolocation, and created the widget, a notification popped up, saying that "The weather service could not find any close city using the GPS cords provided by the phone. Android geolocation system is temporary down or a bad GPS fix is provided by your phone"
I've tried reinstalling, flashed to the older CM and it worked. Accuweather works, but it only shows my zip code and the temp is off by about 10 degrees.
Maps is showing my exact location.
My second problem is with facebook syncing. I have my facebook friends syncing with my contacts. Only a few random people's pictures are showing. I have to actually go to their contact, and click to view their profile and then after that it'll show their picture.
Does anyone else have these issues?
I did have a problem with a Slayher kernel this morning, it worked for 2 days and then went into a bootloop. I guess I'll find a new kernel.
+1 on ChevyNo1's 1.25 ULV here running very fast.
Geolocation for BW is fixed now!!
kiki2025
