Problems with contact ring tone?
chazm
98
Does anyone have the same problem as me? When using sound boards i can't personalize a ring tone for an individual contact. It automatically defaults to my default ring tone.
i don't know but i tested "Send To Voicemail" on the Contact List and it worked great. pretty cool feature!
whenever I "assign to contact" a ringtone, it doesnt work. I have to actually go to the people app, and then choose a contact and under the ringtone part choose which one I want and then it works.
I'm not sure what you mean. The only way I know how to assign a contact is by going to people and changing it groin there. Mine doesn't work that way. Whats the other way?
Help please - I don't know if this is the right place for this, if not sorry. I don't really know what I did but when I try to assign a ringtone all the defaults are gone and under settings>sounds & display the phone ringtone setting only gives me a box that says Zedge then Andriod System the ok is greyed out and all you can do is cancel. Any help would be appreicated.
^ I haven't seen this but I can tell you the only fix I had was to reset my phone by going to Settings>Privacy>reset
Actually doing that helped out all the bugs I was getting
Psilocyanide
