Problems with Go SMS pro and my Samsung Galaxy Note 2
Lunnabelle
6
Hi everyone!
I am new to the forum and wanted to say Hello and see if anyone has any fixes or advice about the problem I am currently having. I have read several posts related to this but not exactly the same. I had been using Go SMS pro on my note 2 for a LONG time with no issues concerning the group messaging capability. Actually it was the only messaging app I was able to get this to work on, but as of about 2 days ago this no longer works. I am getting individual texts responses to my group thread conversations. I have uninstalled and reinstalled, I have checked all the settings and nothing was changed. I just don't know what happened. Is anyone else experiencing this problem? I have e-mailed the go team to no avail, so I feel stuck. Please if I left out any information that could help let me know.
Thanks. :)
Well atleast you had it working for a bit. Mine has never worked....
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
I guess I should just be happy I had it then. I keep trying Handcent now and its just not working either which means I now take forever answering all the individual texts from all my iPhone using friends. UGH! :-\
Try going to;
Settings > advanced > send settings>then check the box for "MMS Group Chat
Then restart phone.
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
Hi, Thanks! I tried that and it didn't work. I'm starting to wonder if maybe I need to do a factory reset. :(
Oh no.
Ok try this one.
Settings> Basic> running mode> highlight "ProMode> confirm
Then restart
Hope this works
thank you....but when i send sms to any number my sms was recieve but when i send to the one number i show message delivered but dont go...why??
Samsung updated Note 2 few days ago. My Go Sms works except I can't delete the msgs. The stock msgs also show although I have checked sms to disable the stock msgs. I then noticed (using Apex) default applications that only choice given was stock messaging service which I couldn't clear. Today it's gray with no choices but don't know yet if Samsung update caused problem. Maybe they fixed it. I had written note to Go SMS when this happened.
Estherlampard
