Problems with phone alarm
M Newton
Hello,
Twice this week my alarm has not gone off and when I look at my phone it says alarm silenced after one minute (which is not the case). Any advice?
Thanks!
Hello,
Thanks!
Can't believe that this is still happening on Samsung phones! I had the same problem ages ago when I had an S2 and an S5 Mini. The solution for me was to change to a different clock app. I used both Timely and the standard Google Clock app and I'm pretty sure it sorted the problem but as it was so long ago I can't be 100% sure. I also disabled the standard Samsung clock app.
noroldie
