Problems with responsiveness on SprintvGS4
TheRyland
15
Does anyone have problems with lagging when you swipe between pages or scroll on pages or webpages? This is annoying me. Any suggestions? This is my second GS4.
there are some sensors that are awaited interaction with you that created that lag. you could turn it off or adjust and enjoy
Check out this link - Common Galaxy S4 problems and possible solutions | Digital Trends
Specifically,
Go to Settings > Developer options and scroll down. Try changing Window animation scale, Transition animation scale, and Animator duration scale to Animation is off. If you don?t see Developer options then you can unlock it by going to Settings > More > About device and tapping the Build number several times (you should get a pop-up message when developer options is unlocked).
