Process com.android.systemui has stopped
Status
Not open for further replies.
i am having the same problem "error Process com.android.systemui has stopped" on my samsung galaxy light i have reset, restored to factory and removed the sd card . i have somewhat pinpointed the problem just don't know how to fix it. i can uninstal all updates to the app called google app and everything works just fine i reinstall YouTube, google app comes back. so instead of unintalling updates were it gets rid of everything including YouTube. i just went under google app and turned it off, everthing working but i would think that's gonna need to play a role in something i use so how can i fix this.
I recently had the same problem with my Samsung Galaxy S3 Neo. I fixed it by uninstalling the new google update, many others also fixed it this way. Hope this will help you and others!
I had the same issue wit my Tab3. Going to the Play Store and uninstalling the Google app cleared thepproblem. Thanks for your advice.
hello, recently had this problem with my samsung galaxy tab 3. It seems that google's latest update was causing the difficulty. Go into play store > google > uninstall and it should remove it's latest update. I found that this sorted the problem and the message no longer appeared. It must be a fault with google's software. Hopefully this works for you too.
thank you! Awesome suggestion! Thank you!
Status
Ariyanto darmana
