Progress report... And some some stupid questions (Forgive me)
Did you ever install Blackhole ROM per chance? It actually has that rectangle over the Verizon as the boot animation (black hole...get it? :)) but I would think Odin would nuke that. How long have you let it sit before turning it off? First boot can take a while.
You have a recovery? Stock or cwm?
Do you happen to remember which Voodoo kernel you flashed?
Hop on the IRC channel #samsung-fascinate if adrynalyne is there and in a good mood he is the un-bricker
Reactions: TheANARCHY
I'll do that as soon as I get the chance thx for that. I'm starting to nail down this I think. Each time I redo the Odin flash to stock I get the little rectangle to go away more and more. I'm not going to be bested by this phone. I will prevail!
good attitude. try formating your sd card(if you cant boot use a pc adapter card thingie). then reflash via odin. however it sounds like a hardware problem to me. i dont think you did that though. i cant see how a couple of wrong flashes did that. Lord knows i have bricked my phone enough and have always been able to get it working again. i certinly have not damaged any hardware. i think you just have a bad phone, timing is coincidannce. dont forget to flash back to stock DI01 before you mail it back, even if it wont boot up.
I'm rooting for you!
Clockwork recovery?
Remember if Voodoo was for di01 or dj05?
BeshevGames
