Proper way to calibrate battery?
mustafu
Simply Winning
Jul 19, 2011
117
15
18
I must be doing it wrong somehow, phone went dead and when I plugged it in and turned it on, it was at 14%. What's the right way to do it? Thanks in advance
I haven't had any issue with the method I use. So I will offer it.
The general idea is to charge the battery to the fullest point possible. I do this by loading a backed up froyo ROM setup without any apps this is really only to get the backup to load up faster. I use froyo so it can stay off while charging. I then plug the phone in and wait till the charging animation stops cycling and wipe the battery stats/history. Turn it off again and let the charging continue. I repeat this until the charging animation stops in less than 30 secs. At this point the battery should be as charged as possible. Go into recovery then unplug the charger and then wipe the battery stats/history one last time.
Now go ahead and use the phone normally but don't plug it in or turn it off till it is at the lowest % you would like to charge it from on a daily bases. I suggest no lower than 5%.
I also agree with the above wipe for froyo (as that is what I've done as well for months-& no issues).
Now the question is how to do a legit wipe for Ginger Bread users?..
Tapatalk via OV
What is this wipe/calibration/configuration thing you guys are talking about? i've never heard of it before o.O
Also I stopped in to ask about how vulnerable todays phone batteries are to overcharge fatigue (not sure if thats the right term but yea).
I only charge my phone to 95-100% and then unplug it. however my girlfriend leaves her phone plugged in overnight every night, from 10pm to 6am. In the past I knew this to cause battery damage or wear out, and eventually the phones would not hold a charge for more than a couple hours. Is this still a concern today or am I alright to leave it plugged in overnight?
Since these won't charge while powered down (at least from what I've heard) I'd imagine you could just boot to recovery to do the "top-off" charge and then go from there. It may not be as absolutely accurate as the Froyo method but I have a feeling it would be close enough.
Yes battery technology has come a long way. The Lithium Ion batteries used in these actually prefer to be kept on a trickle-charge all of the time. There is also circuitry built in to the phone itself to prevent overcharging so no worries.. just leave it plugged in whenever you can and don't worry about leaving it on the charger overnight.
Now if this used the old-school "Ni-Cd" battery then I might be giving you different advice, but it doesn't!
Reactions: mustafu
Yes, that seems to be the only way.
There's even an application on the market (battery calibration)..
However I would rather use recovery.
Thing is why haven't any deva's thought of incorporating a battery percentage calibration tool for custom GB rom user's within recovery?
Would seem 2nd nature to incorporate such a utility within recovery & maybe incorporate it as a defuelt system off function with a charging interval.
Am I on to something or am I in the clouds playen on a rainbow while riding a unicorn while chasen leprechauns?....
Tapatalk via OV
After flashing the latest mirage that now has offline charging, I tried this today: Kept charging, booting into recovery to wipe battery stats, then reboot to watch the charging screen. Kept doing this till charging stopped in less than 30 secs.
So far I've been off charger for 3 hours, moderate use (wifi) and the battery still has to drop below 100%. Obviously that's just a display error as the battery must have drained some. But I assume it will rebuild stats and report accurately after a few charge cycles.
In any case would it seem like more juice was squeezed into the battery. Hopefully that'll prove to be a good thing and not harm the battery.
Thanks a lot for sharing. I never would have thought of this myself :o
Sent from my LG Optimus V CM7/IHO
Reactions: mustafu
^^Boot into recovery (hold down home-VolDown-power), select advanced-> wipe battery stats.
Edit: you're supposed to only do it with a fully charged battery. Hence the top-up charging procedure described by zedorda above.
Thanks I tried it and my apps messed up I just got every thing fixed will try again later
The GB roms now support charging while being off (IHO and Harmonia).
Yes this is true, however at time of posting the off charge was not in effect for our OV roms..
So happy Harmania2 now allows powered down charging now.
A few other OV GB roms now supports this feature as well.
Tapatalk via OV
