Provider and WiFi Connection issues (T-Mobile)?
wezi427
95
Since the 6.0.1 update I've had issues with losing connection with WiFi and provider network (T-Mobile). I've never had the issue before. Has anyone else had this issue?
I wonder if illiterate people get the full effect of alphabet soup
It says connected, but no internet.
I'm seeing a return of an old problem. Phone calls that go directly to voice mail without ringing the phone. Not good.
And annoying because if you want to get T-Mobile to check it out, you need to call from a differnt phone/different number and have a wifi connection. Things that I can't do easily either at home (only one phone #) or at work (no wifi connection).
I haven't had that issue.
I'm having the exact same problem at work. It has the exclamation mark by the wifi everyday. "Connected but no internet". I tried to turned off the data and see if wifi actually works. I can surf fine. It started this after the 6.0 upgrade. On 6.0.1 now. This is not an issue with the home wifi. Not sure why.
It's really annoying. They really need to fix this.
I'm having the same problem after 6.0.1. Multiple disconnects every day from home wifi network. Also have the connected but no internet problem. Nexus 7 2013 wifi with 6.0.1 connected to same home wifi doesn't exhibit these issues at all.
That's the exact issue I'm having. My tablet and all my other devices don't have issues with connections.
For what it's worth, I switched off wifi calling since it's not really an issue for me and the constant wifi disconnect/reconnect resulting in wifi connected but no internet has stopped for now. Back to buttery smoothness.
Hixson21
