[Q] Samsung Galaxy Nexus Stuck at ClockworkMod Recovery
Abhi88
3
Hi, I have this Samsung galaxy Nexus I9250.I unlocked it and was trying to root it. Here is what I did:
Download: GalaxyNexusRootMac.zip Here(Dev-Host - GalaxyNexusRootMac.zip - The Ultimate Free File Hosting / File Sharing Service)
Step 1: Download the link above
Step 2: Extract the zip file and move the extracted folder into "Downloads" folder
Step 3: Open Terminal and type:
cd Downloads
cd GalaxyNexusRootMac
./fastboot-mac oem unlock
Step 4: Plug your phone via microUSB and enter into bootloader mode (Press volume up, volume down, and power button until you feel a vibration)
Step 5: Press volume up and power button to select "Yes" (It says may void warranty, don't worry because you can always lock the booloader if you want)
Step 6: Go back to Terminal and type:
Type for GSM:
./fastboot-mac flash recovery GSM_recovery-clockwork-touch-5.8.0.2-maguro.img
Step 7: Enter into ClockworkMod Recovery Mode (First enter into Bootloader Mode then press volume up twice and power to select "Recovery")
Step 8: Select "Reboot System Now" using volume and power buttons.
Step 9. Once your phone has finished rebooting Go back to your computer and go to "Downloads > "GalaxyNexusRootMac" and transfer "CWM-SuperSU-v0.87.zip" into internal Sd card phone.
Step 10: Enter into "Bootloader Mode" (Power off phone, hold down volume up, volume down, and power button until you feel a vibration)
Step 11. Press volume up 2x (twice) and power button to select "Recovery"
Step 12. Select "Install Zip from Sdcard" > "Choose Zip from Sdcard" > Select
"CWM-SuperSU-v0.87.zip".
Step 13. Choose "Yes" > Go Back > Reboot System Now
Found these instructions at the thread: http://forum.xda-developers.com/show....php?t=1790399
My phone is now stuck in recovery mode.
I have tried doing some troubleshooting with my little knowledge:
Perform Wipe data/Factory reset (this will delete all apps and their settings and game progress) and choose Yes on next screen to confirm the action. Then perform Wipe Cache Partition and once again hit Yes to confirm.
Return to CWM recovery main menu and select Mounts and Storage > Format / data and click Yes on next screen to confirm.
From the main menu of CWM recovery, go to Advanced and choose Wipe Dalvik Cache. Then hit Yes on next scrand messed up the whole situation.
It currently shows:
ClockWorkMod Recovery v5.8.0.2
-reboot system now
Standard options
I'm using a Mac and have no idea what to do now. Please help.This is my first attempt at doing something like this. Apologies for any lame input.
Please Help
cinemacritic
