Qi or PMA Wireless chargers confirmed to work?
mark959022
I just got the new DT2 coming from the old Droid Maxx and I am not able to get the DT2 to charge on my Incipio Ghost 100 1 amp charger. I only tried using it with the phone case on. I am using one of those naked cases so it's pretty thin. Anyone have recommendations for a good wireless charger for the DT2 that you can confirm works well with a case? Please only make suggestions if you have the DT2 and confirmed that your wireless charger works well and also the ease of the phone placement to start the charge. thanks
I only have a Nokia DT-900 wireless qi charger. The T2 works great on it
My TyltView works just fine. And my T2 is in the Verizon Shell Holster combo case.
Have 2 of these and no issues to speak of. I will say that I could drop my Nexus 5 ANYWHERE and it would work. With the Turbo, I do need to put it on straight.
..any reason why you didn't try it with the case off?
Posted via the Android Central App on the Moto X Pure Edition
One odd thing about about the Nokia Qi charger with the Turbo is there is no way to have the phone off (for faster charging) if it is on the pad. Put a phone which is off on the pad, and it will turn on. Have a phone on the pad and turn it off, and it will immediately boot back up. My Nexus 5 did not behave in this way.
Motorola phones have been this way since they supported wireless charging. I suspect the reason is that wireless charging requires some critical processing by the phone, to shut down charge in order to protect the battery when it gets warm. Samsung evidently built in this processing to their bootloader, while Motorola decided to make it in a way that required the OS to provide these services.
I suppose I can try it if someone would like to know but taking the case off is a PITA. I would rather just throw it on the charger and not worry about it till morning. The Droid Maxx phone on the Incipio Ghost had to be positioned perfectly or it would toggle on and off or not charge at all. A few times I woke up to find it didn't charge at all. I will order the TYLT VU tonight and post back if I have any problems with it. Thanks to kmf1 for the suggestion. I have always heard good things about this brand.
I can second the tylt vu, it works great, even with the Verizon holster shell on the phone.
Marabishi
