Quadrant Standard benchmark
thats a tiny bit under average (note results varies if done at different time etc)
But the nexus 4 results are extremely wild as quadrant isnt able to cope with android 4.2 effectively yet and therefore the nexus 4 scores are alot lower than if it was running android 4.1
So do not worry thinking that your nexus 4 is slower than a samsung galaxy s3 its just that quadrant has been slow to update.
If you use any other benchmarks you will find that the nexus 4 scores very respectively coming in as one of if not the fastest smartphone currently availalbe!
Also some results you see may be done using a custom rom/root which will change scores compared to an stock/unchanged nexus4
HTC Droid DNA running "Cryorom 1.1.2" by My Fish Bear
Android 4.1.1
HTC Sense 4+
Quad core running at 1786MHZ
Gpu running at 400mhz.
Total: 8796 - CPU: 20683 - MEM: 10990 - I/O: 9825 - 2D: 321 - 3D: 2160
DannaOgle83
