Quadrant Standard score's
Few things. First if you're running the Blur home it will take a toll on your performance. Second if you have all 5 (or 7) homescreens loaded up with widgets and if you have multiple accounts active chewing up memory and processing cycles that too will affect your performance.
People who get 1300+ right now with stock everything are miracle workers :p
I'm running 1200-1300 every time. All 7 home screens have at least one widget and four shortcuts on them. I'm even running Copy Paste It and a couple other apps that are always running in the background. Along with the standard Blur.
I would suspect bad app choices and loading up on too many apps that sit waiting in the background. I also don't go too crazy with the widgets, having maybe 1 on each of the 7 screens. Loading up on those would probably cause the same issues.
As well, I'm not running a live wallpaper, but I might test it out, just for ****s and giggles.
baxter.. you running a live wallpaper? the live super mario wallpaper brought my quadrant score from the high 1200s down to ~800
Running launcherpro plus. 5 screens with one full of widgets. I ran it after running all day and got 1217 then 1277 after a reboot. Then ran shootme and got a 1232 screen cap.
Sent from my Rooted DROIDX using Tapatalk
Nope but I did find the Moto Social Networking was running in the background ever though I don't use it. I killed it and turned off-Wifi and got 1273 this morning. Looks like what is running makes a big difference.
running android 2.1, launcher pro plus with 7 homescreens and beautiful widgets....and lots of crap of all but one of the screens.
Score: 1284
Running the Blur and all home screens packed with awesome goodies and widgets :)
*Running leaked 2.2
Here's all of mine from 2.1 & 2.2
The only one I don't understand id the NenaMark1 scores going down on 2.2
I did note that when I run NenaMark1 from an icon inside a folder, afterwards I can't open that folder again unil I do a power cycle, so I suspect a memory leak or some other problem on that one.
Droid X Benchmarks on 2.1
Quadrant - 1275, 1263, 1277
Linpack - 8.214, 7.698
Gears for Android - 61 fps, 61
NenaMark1 - 24.1 fps, 24.2 fps
W 2.2
Linpack 14.158, 13.303
Quadrant 1325, 1363
Gears- 61, 61 fps
NenaMark1 - 21.6, 22.1, 21.0
Sent from my DROIDX using Tapatalk
I made a youtube video under my channel gmod10man. The scores I got before and after running 3 times in preformence mode were: Before: 1172 1295 1254. After: 1337 (im not joking) 1297 1457
gocoronago2021
