Question about battery
bed269
107
7
I stream music for 8-10 hours a day and during this time my phone stays plugged up. Is this bad for the battery?
Sent from my ADR6400L using Tapatalk
Heat is bad for the battery. Make sure you get air flow around the phone to keep if from getting hot.
On a side note, if you use Pandora. I had Pandora on mine. I seldom used it. Occasionally I would get a FC error even without running Pandora. So, I assume Pandora was running in the background. I deleted Pandora, and my battery life is definitely better, even though I didn't use Pandora.
I use Pandora, but I have recently started using Slacker radio. Basically the same thing. Just a different experience. I got a few freezes and FC's with pandora so switched.
I keep my phone on the kick stand and it keeps pretty cool.
noroldie
