Question about Jelly Bean Widget move problem
vins18
Hi everyone, i need some help for this problem, i asked for help on XDA but i didn't get an answer :(
Have you ever seen this problem with this new feature of JB ? :
http://www.youtube.com/watch?v=SbzHYeM35MI
Moving widget is not smooth, when i move it, i don't understand why.
I'm in Stock JB 4.1.1, no launcher yet.
Thank's a lot :)
Hmm, I'm not sure. If there is something wrong with it I didn't see anything out of the norm... are you talking about the animation when the widget moves to a free slot?
Widgets do animate slightly by hopping around when you're holding another widgets on top of it (ie. telling you where it's going to move) but mine doesn't jump around THAT much or that fast.
Still, not sure it's a something to concern yourself over... How often are you moving widgets around that it's really going to bother you? :-\
I doubt there is an easy fix without re-flashing something new.
Have you tried messing with the Transition animation scale, Animator duration scale etc by shortening or lengthening the time? Might be something to look at. Its under Developer Options and close to the bottom.
Just messing with it myself. That has no effect on the wiggle of the widgets when being shuffled around.
But a good guess! :)
CGKalexander
