Question about using the wireless charging pad?
Keith Molloy
220
Hey guys! Bought the official samsung charging pad today, for novelty factor more so then anything else if im honest! It was €55 to buy online here in Ireland (which is crazy money) but i got it along with a case for only €40 as part of a deal so i thought why the hell not. It came without a cable so naturally i assume i must use the fast charge cable with it? Here are a few questions i have.........
If using the fast charging cable with it , does that mean i will be getting fast charging capabilities from it? (iam assuming not)
If its generally not a good idea to use fast charge plugged in over night then does this apply to the wireless pad in conjunction with the fast charger?
And lastly. Can i run the cable from the usb port on my computer or does it have to be plugged in to a socket when using the wireless pad? The answers may seem obvious but just asking none the less! Not taking any chances with this baby ha
1 - No fast charging only works when using the compatible brick and plugging it in. Wireless cannot push it as fast.
2 - That is up for debate. I would say there isn't an issue but if you're worried you could just put it on the wireless pad instead.
3 - You could do this but I would recommend to use a wall plug as it will get better power.
Thanks mate. So essentially, even though i will be using the fast charging brick and cable , because its connected to the wireless pad it loses its fast charging capabilities ? and therefore is also safe to leave plugged in over night?
Yep :).
One last thing by the way. Will it charge wirelessly with the clear cover from samsung still in place? I assume it would seen as the cover came with the charging pad but some online reviews say it won't charge if you have a cover on. I'll find out for myself when iam home later i guess
Yes it will charge just fine with the case on it.
I use a wireless charger but I found that my phone gets really warm. I have a thin samsung flip cover on the phone and it charges just fine with it on. When I charge the phone "normal" the phone doesn't get hot, only on the wireless charger.
It is normal to heat up some -- no worries :).
Is it ok to use the older samsung charger that came with the s3 for the wireless pad?? The fast charger cable isnt long enough for me! I want to use the "wireless" pad on my desk but it wont reach with the cable length of the fast charger
