- Feb 6, 2017
- 97,620
- 13,656
- 113
Ok your welcome! Hopefully everything works out .Ok sir, I will be back after I got a new one.
Thank you very much
Thank you very much
Hi, if still having a issue then I recommend taking to repair center could be something different like motherboard but needs to be professionally checked .Hello again!! Today I have change a new battery but the problem is still there. What can be the cause of this issue??
Thank you very much
Loose connection?I took the back off and moved the battery a little bit without removing it and it started charging
